System memory 90%+ on dedicated BI system, something hogging RAM, thoughts?
nutshellml
Jun 22, 2016
195
15
Afternoon all (or I should say Fenderman, since you have helped me with almost all of my issues)... So as you advised, dedicated i5-6500, 8GB RAM, only running BI4, removed AMD video card, have 5 4MP IP Cams and 2 Foscams all recording direct to disk. Seems like it may not be BI4 issue since BI is usin gonly about 3-4MB RAM. Since yesterday, my CPU has possible crashed or memory overloaded forcing me to reboot. (I didn't have Remote desktop connected). I'm trying to figure out what's wrong. It's a clean windows install. I attached a shot of my Task Manager sorted by Memory usage. Any help would be greatly recommended.
There is a memory leak in some intel drivers...there are several threads discussing this..try the latest intel driver.
Ran INTEL Driver Update Utility and only update was a Generic Chipset Device 10.1.1.14. Right now I have 15.2.0.1020
Intel HD Graphics 530
9/29/2016
Version: 20.19.15.4531
Not sure there's a later driver
Tried that and got installation package not supported by processor type. Also tried manually browsing to driver.
ok, let me search for the thread and report back, since running SETUP after download doesn't install it.
Tried the manual install, but i keep getting the "windows determined driver is up to date".
ok GOT IT.... I Uninstalled totally, then ran SETUP from the driver download and was able to install it. Now total memory showing 62%, that's BI, taskmanager, windows explorer and remoting in.
THANK YOU!
THANK YOU!
keep us posted..which version did you install?
Reactions: Mike
Looks like it worked... I'm at about 57-60% last I checked. This was it:
Package: 523147
Intel® Graphics Driver: 21.20.16.4542
Release Date: November 3, 2016
Reactions: nayr and fenderman
can that i5 really only handle around 8 cameras?
havnt tested that version of cpu yet
