System config question
car_wash_guy
Nov 15, 2015
29
Not sure the correct way to set up my system, and what, if any, would be the benefits/drawbacks of each?
How should I setup the router, switch and NVR?
NVR
Cable Modem---------> Router------<
POE----------->Cameras
or
NVR
Cable modem--------->Router---------POE---------<
Cameras
ETA:
The forum is messing up my diagram,
Basically, should the NVR be connected to the router or switch?
This is the switch I'm using : http://www.ltsecurityinc.com/more/poe-switches/poe-switch-poe-sw2402l-f.html
It has the
24 PoE Ports at 10/100 Mbps + 2 Gigabit Uplink. I assume I plug the router into one of the 24 10/100 ports? What are the 2 gigabit ports for?
If you have room hook the NVR to the same switch as cameras..this way no traffic passes through the router.
Ok. I have a 24 port switch and 16 cameras, so that's what I'll do.
This is the switch I'm using : http://www.ltsecurityinc.com/more/po...sw2402l-f.html
It has the
typically the only thing connected to the router is the cable modem on one side and the switch on the other.. everything else goes into the main switch.
if you have one network/subnet, the router simply routes traffic too/from the internet and acts as a firewall and dhcp server.. also hopefully a VPN server.
