Maybe I’ve been using the profile part wrong. The part I guess I don’t understand is once you select sync with profile one you don’t ever get an opportunity to change the motion sensor, such as marking certain areas for each camera.Select Profile 1 from the drop down that currently says Profile: 4 Home Front Doo...
If you are happy with the Trigger settings in Profile 1 and don't want to copy them to another profile, check the Sync box. You can then set your schedule to switch to this profile and then make changes to the Profile 4 Record tab if you want it to be different.
This is because you are syncing it with Profile 1. Which means whatever Profile 1 is set to is what you get.Maybe I’ve been using the profile part wrong. The part I guess I don’t understand is once you select sync with profile one you don’t ever get an opportunity to change the motion sensor, such as marking certain areas for each camera.
If you want Triggers for Profile 2,804 to be different than Profile 1, don't check that box, and set them as you desire.
is there a way to multiselect 40 cameras at once and change them all to say "sync with profile 1" for a new profileI created Like profile 4?This is because you are syncing it with Profile 1. Which means whatever Profile 1 is set to is what you get.
I don't believe so.is there a way to multiselect 40 cameras at once and change them all to say "sync with profile 1" for a new profileI created Like profile 4?
