Hoping someone can help...I have 5 Foscam cameras and one Amcrest camera installed in my house that were working fine through Blue Iris with my old Belkin N1 router. I just upgraded to a Linksys AC2600 router, created the port forwarding requirements for all the cameras (similar to how I had them with the old Belkin router) and now I'm am getting a "No signal" message on all my cameras. I have been using an account through Dyn.com which Linksys does support for this router and have not changed anything within Dyn.com. I should note that I can see the cameras wirelessly through the Foscam and Amcrest software, and I can also see them both wirelessly and outside my network with my IP Cam Pro app on my Ipad (I checked by driving about a half mile away and was able to see the cameras on my app so I'm thinking the port forwarding menu is set up correctly for the cameras?). The Blue Iris was always just set up to view when I was outside my local network so I haven't checked it wirelessly to be honest...but given that I can see my cameras through my camera app on my Ipad when I'm outside my LAN, I'm thinking it must be a Blue Iris or Dyn config issue, but I'm not quite sure which parameters I would need to change. I'm also very confused as to why I can view my cameras remotely through the IP Cam app, but when I type in the remote address for the camera, it won't connect. All of this worked fine with the old router so I'm thinking my config is off somewhere. Any advice you can give would be appreciated.
