Hi all
I can’t seem to find what I need or I’m messing up the terminology used
- I have a virgin media route
- an exist hardwired Ethernet cable to out buildings
- need to split this cable with a 4 port switch ( hardwired cameras)
- also need it to repeat the existing WiFi - which is too far away from the existing WiFi signal to boost it, I can’t install nothing between the sites
do I need a router to piggie back off of the existing router?
Thanks
Thanks
