Hello everyone,
I am dealing with a malfunctioning Eyes.sys NVR, with only 3 ports operational, which has left my other 5 IP cameras without power. I believe my cameras operate on 15 volts. In an attempt to resolve the issue, I've tested a few other PoE switches that I have on hand, but unfortunately, none of them have worked.
I had also purchased a replacement NVR, but it turned out to be a 12V unit and did not work with my 15V cameras. Given this, I would prefer to find a switch as an alternative to purchasing a new NVR, since I can easily obtain switches for free. However, I am unsure of what I might be doing wrong or what specific type of switch would be compatible with my 15V cameras.
I am seeking recommendations for a switch that would be suitable in this scenario, or any insights on what I might be overlooking in my attempts to resolve this issue.
Your expertise and suggestions would be immensely appreciated.
For reference, here is a link to the newer model of my setup: 8pcs 2.8mm Lens 4K ColorVu Audio PoE Dome 8MP Camera System.
Thank you in advance for your help!
