Folks,
Building a system, and I'm at the switch. I'll have 8 total cameras:
(1) Axis PTZ with it's own injector since it has a heater, so skip it;
(6) HDW5231R or HDW2231R (or a mix);
(1) SD1A203T PTZ.
So 7 needing POE. Seeing specs rating them all, say at ~10W, what is the minimum switch wattage I should shoot for? Will an 85W switch (this one) provide enough overhead, or should I go 95W or higher, say this one? I plan to segregate the cams onto a vlan (maybe) but dont necessarily need to as I plan to set a BS gateway in the settings. Thoughts? Recommendations?
(1) SD1A203T PTZ.
