sparker
I am using the V1.4.62 build 180726 firmware after hearing it is more stable than 180515 (plus it is newer, I believe it is a Nelly firmware) and 180809 (ding dong at bell doesn't stop) Hikvision removed the firmware from the EU portal for the DS-KB6003-WIP but the latest firmwares are still available on the Dutch site
As you can see 180809 is saved at the top level, it's probably the las ever version they did, but in my case the chime at the doorbell is stuck when someone presses the doorbell, so you'll need to test if this happens for you or use an older firmware.
