P Pat_2 n3wb Sep 21, 2017 2 0 Sep 22, 2017 #1 hi I was wondering if we can add all the camera that are plugged to the Swann NVR to blue iris Thanks
fenderman Staff member Mar 9, 2014 36,891 21,411 Sep 22, 2017 #2 Pat_2 said: hi I was wondering if we can add all the camera that are plugged to the Swann NVR to blue iris Thanks Click to expand... yes, you need to pull the streams from the nvr itself...or use a poe switch and pull the streams to both simultaneously..
P Pat_2 n3wb Sep 21, 2017 2 0 Sep 22, 2017 #3 Thank you very much for your help! Would you happen to know the exact streams? I've looked at the streams from the NVR8-7200 but they don't seem to be the same, unfortunately. Thanks again!
