hi folks,
I have the above system and something strange is going on with it. I can live view remotely on my iPhone without any problems at all, but when I try to use the playback facility, I get about 2-3 seconds of the recording and then the app crashes. I never used to have this problem, and the issue doesn't happen when I'm on the same wifi network as the system?
I have port forwarding enabled on the router (plusnet hub) so I'm now stumped as to why I'm having this problem?
Also, on the sensitivity scale of 1-50, which is the most sensitive end of the scale?
Thanks in advance.
Thanks in advance.
