- May 22, 2017
- 4
- 0
Hi newbie here hope you can help
I have a Swann NVR and as you know they can have very noisy fans, i haven't taken the box apart yet but would a Noctua NF-A4x10 FLX 40mm x 10mm Low Noise Fan work/fit in the box from what i have read there are 2 fans one for the country and one for the power supply and it is this one that is noisy it runs 24/7 and when there is no other noise in the room drives you mad.
If it fits is it an easy fix or do you have to alter anything.
Cheers
Cheers
