mat200
- Jan 17, 2017
- 17,464
- 29,437
CAT5E UTP TIA/EIA-568B 4PR 24AWG CM (UL) E475339 PATCH CABLE
cant get a weight yet as I dont have a scale. I am considering getting CAT6 and running that. Might have to put two POE switches and run them to a single line. If I can use two rooms that (1. has a router, and 2nd has an ethernet port and run them in there, that might help me from having to run a lot of wires outside)
HI @pclist18
Marking on cable look good.. was looking if it was marked CCA, which you do not want
