Rolszak
Hello Everyone! Just an FYI, PoE cameras many times have 2 wires that are "Shorted" for lack of a better term. i.e. one wire connects to quantity 2 pins. I ended up soldering 2 pieces of solid core (24 AWG) to the SV3C stranded copper. 2 different connections require this on each pigtail. I soldered each connection, used shrink tubing on each "2 to 1" solder connection and then used shrink tubing to enclose the exposed, UTP 24 AWG wires. be careful regarding the RJ45 connectors that you use. There are connectors for solid core wire and stranded wire and some that will handle both. Also, peopleI have attached a document that came directly from SV3C Technical Support. The problem is; I just cut the pigtail off of my 5th camera (10 more to go) and the wiring colors are COMPLETELY DIFFERENT!! I have spent a great deal of time removing the vinyl jacket from the female RJ45 on the pigtail. I will post a follow up in case anyone else runs across "non-standard" wire colors.
