- Mar 13, 2020
- 4
- 0
Hi
I have an SV3C POE camera that has been working perfectly fine for the last 2 years. I'm moving out, so replacing my Blue Iris set up here with a HiLook NVR for easier management for my parents. I plugged my camera into the NVR but it couldn't detect it, then realized I needed to change some settings on the camera itself, so plugged it back in to my POE switch to connect to the camera and it is now no longer appearing on my network.
I've tried a different switch, POE injector into my normal switch, heck even plugged directly in to my router and the camera doesn't appear on my network anywhere. When I go back in to Blue Iris and search for all cameras, only my 2 others show up that I didn't try on the NVR.
I'm at a wits end - any suggestions from you good folk?
Cheers
Cheers
