SV3C B01POE-5MP-HX stream url?
JimLS
Feb 8, 2020
49
22
Illinois
I set up some 4MP SV3C cams with rtsp:/192.168.1.100:554/stream1 for low res and stream0 for high res but the new one is different and trying to figure out what to use. After a bit of searching I found that
rtsp:/admin:[email protected]/11 works but not sure which stream it is for. Anyone have info on both streams or can point me to that?
A search of SV3C's site with your model number only provides the following camera, the 4MP model # B01POE-4MP-HX. However, it does provide 2 URL's that may be of some use to you.
I can only assume that the first is "main stream" and that "vice stream" correlates to "sub stream". Note that in both instances that port 554 is right after the cam's IP address, preceded by a colon.
Also note that there are 2 "/" after "rstp:", the forum software won't allow 2 to be displayed consecutively here.
Code:
rtsp:/ip address:554/11 vice stream:rtsp:/ip address:554/12
Reactions: rdwilson
Thanks! I did a few more tests based on that and found that the user and password isn't needed. I also didn't include 554, maybe that's the default for rtsp? 11 is the main stream, 12 is the lower res stream. I checked the resolution of both streams with vlc. I ended up with this format:
rtsp:/192.168.1.103/11
Reactions: TonyR
