- Nov 30, 2017
- 187
- 96
Hey Fans,
has anyone used one of these sun/rain shield on their cams? would you recommend? Or, has anyone done a total DIY solution using some products from hardware store?
This weekend, I was doing some testing and dry run for cam locations. Listening to advice here, ideal spot is right above the wood frame of a two car garage roll up door, at both end edges. That area is significant lower from the eave so I anticipate rain and possible sun flare concerns.
This shield will be for the famous 2MP starlight turret. The way I understand its install, I would need to install the turret to a junction box, then Dahua's shield gets attached to that junction box.
Dahua TechnologyPFA200W Sun/Rain Shield for Select Dome Cameras & Junction Boxes
I also found a similar item by HIKvision ($21 at BHPhoto. The price is reasonable enough to get one as a trial, just to play with it
HikvisionSRS Series Anti-Corrosive Wall Mounting Bracket (White)
