return those crap cameras...that is be best solution..blue iris is generally compatible with any camera that can send an onvif or rtsp stream....download the demoHello...
I'm new here, hello to all. I recently purchased 2 Sumpple S610's and no at all impressed with their software (desktop & phone). I'm wondering is the Blue Iris package will be compatible with my cameras?
Thanks...
these cameras sell for 179 on amazon...for that kind of money you can buy a quality dahua starlight varifocal turret...you likely dont need the ptz...its a gimmick for all but a select few applications...Fenderman... well, tell me how you really feel...lol. While I understand there may be better cameras, price is a strong factor in many purchase decisions. some of us don't have the budget of others.
Also, like others I suspect, are not professional up camera people. Could you help me understand the terms you used about "streams"?
Thank you...
Really? you man your cameras 24/7? are these used for security or dog watching...dont by crap cameras by looking at specs you are just asking for a world of hurt and you are not saving any money, rather wasting money.Not sure I know what a "turret" camera is, but in my situation I need to pan and tilt the camera. They are mounted on opposite corners of my house such that with 2 cameras I can see 360 degrees around the house.
I will check the specs on if these cameras support those streams.
its fact...its a common amateur move...some folks simply wont accept good advice... I will say it again, ptz is a gimmick in most use cases. Keep wasting your money on low end garbage...let us know how it works out for you.Well... all I can say is... thank you for your opinion.
Camera shaming please...That that PC nonsense to another forum.. this is not an internet safe space . pointing to poor camera choices is beneficial not only to you but others who may come across this thread.. instead of being stubborn and trying to justify your poor choice and lack of research you should be thankful for getting proper advice. It is evident from your camera choice and your lack of knowledge with respect to rtsp and onvif but you did not research your choice. Also note the even if the camera is onvif compliant or can send an rtsp stream it may not be compatible with blue iris..yes you will get an image but it will not be stable as we have seen with Reolink where the company deceptively advertises the camera as blue iris compatible when its firmware does not support iframe interval settings.Thank you for you opinions, however, to be blunt, my original question was about compatibility of the Blue Iris software. I did not ask for opinions on which camera I should buy, or, which camera I did buy. Camera shaming is not beneficial to the poster, nor for others who may come here for unbiased information on their questions.
Thank you...
Thank you...
