Ds-2cd2132f-iws ?
Any camera can be made wifi by using a small bridge...you wont find lots of quality options because wifi is not a reliable solution.Thanks. Yes that is one to consider. The options sure are slim sadly.
I would have a look at :
1) Hikvision DS-2CD2642FWD-IS
http://overseas.hikvision.com/en/Products_accessries_160_i5599.html
2) Hikvision DS-2CD2032F-IW
http://overseas.hikvision.com/en/Products_accessries_157_i5641.html
Look for any model in the Hikvision range with a "F" (on board storage) and "W" (WIFI) in the model number.
There are lots now.
I believe on the 2032F, the POE is in the pigtail making it way bulkier...not sure about the 2642Does one give up anything going with a 'W' or 'F' version?
Extra money and the only ones I can find are Chinese models.Does one give up anything going with a 'W' or 'F' version?
