Suggested new GPU for a new build for a friend? Similar to gtx970
Pentagano
Getting comfortable
Dec 11, 2020
671
301
Uruguay
My GTX970 runs very well with CPAI. But as we know they are old.
What new GPU would compare to a gtx970 in terms of inference speeds? (cudos cores)
Nothing expensive
Thanks
The best will depend on what is important to you.
I value;
low power usage
good price
decent AI performance.
I bought GTX 1650 for all of my Blue Iris machines.
They only use 70 watts
They do all of the coding/decoding for 16 cameras, handle Codeproject AI, and do some other AI/pytorch stuff I am playing with on my own.
If I had to buy today it would be the same OR I would look at the RTX 3050 as the power rating on that is close to 70 watts as well.
Reactions: Pentagano
