That capture is from BI. The one I have needs a wall wart though.
Man, such great detail!
I have two of them that have been going strong. I use 5V POE adapters so I don’t need the wall wart.
PLUSPOE Micro USB Active 5 Volt...
Not sure if your statement was brought about by reading the IP2M-841 specs but FWIW, on its flat bottom it has a brass 1/4"-20 female threaded insert for a tripod!Has anyone ever seen a tripod mount for the hikvision cube cameras? I tend to put them on a tripod for temporary monitoring.
BTW, this might fit that cube cam==>> Ailun Tripod Phone Mount Holder Head Standard Screw Adapter Rotatable Digtal Camera Bracket Selfie Lens Monopod Adjustable Ring Light for Camcorder,Compatible for Most CellphonesDidn't even know that exist. Has anyone ever seen a tripod mount for the hikvision cube cameras? I tend to put them on a tripod for temporary monitoring.
Seems like a good deal for $8 !
View attachment 102136 View attachment 102137
The Hik may be just a tad too big. Maybe this ==>> AKOAK 1/4" Swivel Mini Ball Head Screw Tripod Mount for DSLR Camera Camcorder Light Bracket, Pack of 1Maybe it will work i have a bunch of the hikvision cube cameras they seem to know longer be made. I like to mount them on a tripod for temporary situations or to monitor a vacant houses basement.
