H hotbrass Young grasshopper Mar 16, 2016 99 12 Jan 3, 2020 #1 What does BI do with Substream? Will I save any space or time by turning the substream off? Yes I did a search but could not find the answer. Thank you!
fenderman Staff member Mar 9, 2014 36,891 21,417 Jan 3, 2020 #2 hotbrass said: What does BI do with Substream? Will I save any space or time by turning the substream off? Yes I did a search but could not find the answer. Thank you! Click to expand... nothing unless you specifically set blue iris to pull the sub stream instead of the main stream. It wont matter if its on or off.
D Dennis Ward n3wb Nov 2, 2018 16 7 Fuquay Varina, NC Jan 4, 2020 #4 Is the substream used on mobile applications ?
looney2ns IPCT Contributor Sep 25, 2016 16,752 24,980 Evansville, In. USA Jan 4, 2020 #5 Dennis Ward said: Is the substream used on mobile applications ? Click to expand... It can be, depends on how you setup the camera and the viewing device.
fenderman Staff member Mar 9, 2014 36,891 21,417 Jan 4, 2020 #6 Dennis Ward said: Is the substream used on mobile applications ? Click to expand... only by some, not the blue iris mobile app.
D Dennis Ward n3wb Nov 2, 2018 16 7 Fuquay Varina, NC Jan 4, 2020 #7 ok, I just proved the substream is needed with the gDMSS Plus mobile app. Thanks
fenderman Staff member Mar 9, 2014 36,891 21,417 Jan 4, 2020 #8 Dennis Ward said: ok, I just proved the substream is needed with the gDMSS Plus mobile app. Thanks Click to expand... yes it is. It is also need by nvr's for the matrix view. The OP is using blue iris.
