Not 100% sure but I would assume it is same as Mainstream except Channels 2:Hi All, how can I set up Sub Stream for NSC-DB2?
Sorry, it's good or bad?with the primary stream so slow a 1.6 frames per second there is no need for using subframes. For subframes to work in bI the iframe and frame rate of both streams must be the same.
I know 30FPS is overkill on our Doorbell Cam but I will be changing it as I add more Cams...
How many Cameras do you have on your BI box? I have a 4th Gen. with a Nvidia 970 Video Card.
