Hi everyone,
After learning with some basic lower end cameras (DLink, Linksys, Foscam), I finally bought a Hikvision 2032 bullet which arrived the other day and is my first HD camera.
It's running V5.2.0 build 140721
It's up and operating just fine on my LAN and my Blue Iris setup is monitoring it and recording it normally as well. My Blue Iris app on my iPhone also views it just fine - no issues.
However, it's not very stable at all in my LiveCams Pro app. I know I can view it in my BI app but actually like the LiveCams Pro app too for viewing and also have family members that use it to view my cameras.
Common issues:
1. Camera takes a very long time to load IF it loads at all. 15-30 seconds not uncommon at 720p. I'm viewing my cousin's two 2532 cams set at 720p as well with the app and they come up fine in a couple seconds typically.
2. When my 2032 cam does come up in the app, it typically freezes completely after 5-15 seconds. This does not happen in the BI app.
I'm pretty sure my port forwarding is fine. I set it up just like my other cameras although my other cameras I'm pretty sure have only one port option. On the Hikvision I am forwarding the RTSP port correct? That's the only one that seems to work at all for me.
Any ideas? Happy to add more details if needed.
Chris
Common issues:
Chris
