T Triumph1996 n3wb Dec 20, 2021 1 0 Usa Dec 20, 2021 #1 Has anybody used stride switches for ip cameras? I can get a bunch to use but not sure if they would be acceptable for video. Hers is a link for them https://www.automationdirect.com/adc/overview/catalog/communications/industrial_ethernet_switches Thanks in advance
Teken Known around here Aug 11, 2020 2,039 3,584 Canada Dec 20, 2021 #2 Triumph1996 said: Has anybody used stride switches for ip cameras? I can get a bunch to use but not sure if they would be acceptable for video. Hers is a link for them https://www.automationdirect.com/adc/overview/catalog/communications/industrial_ethernet_switches Thanks in advance Click to expand... The link you provided indicates these devices are standard switches not POE Switches. So, unless you just need a switch for your network no problem. But, if you need to power your IP camera's - no. Reactions: TVille and TonyR
