P passat774 n3wb Jun 17, 2018 28 3 earth Jun 11, 2022 #1 Hello, I have a lorex system and wanted to know what camera people would suggest and why for my cul-de-sac install. I marked the tree with an arrow for the location of the camera. Looking for identification purposes. Reactions: mat200
sebastiantombs Known around here Dec 28, 2019 11,502 27,730 New Jersey Jun 11, 2022 #2 What are you trying to identify, people, vehicles, license plates? Reactions: tech101 and mat200
wittaj IPCT Contributor Apr 28, 2019 32,912 62,983 USA Jun 11, 2022 #3 +1 above! One camera will not be an overview and get plates, especially at night. Reactions: tech101 and sebastiantombs
bigredfish IPCT+ Member Sep 5, 2016 32,968 80,042 The Swamp Jun 11, 2022 #4 Looks similar to my setup. You'll need two cameras, one for Overview and one for getting plates (LPR) Cameras are mounted on a pole approx 20ft back from curb, plate capture at anywhere from 80ft-100ft Recommend HFW5442T-ASE (3.6mm) for the Overview camera HFW5241E-Z12E for the LPR camera Reactions: samplenhold, Broachoski, RyanB and 4 others
bigredfish IPCT+ Member Sep 5, 2016 32,968 80,042 The Swamp Jun 11, 2022 #5 And if you want to ID people at varying distances, you’ll need a 3rd camera Reactions: samplenhold, Broachoski and sebastiantombs
P passat774 n3wb Jun 17, 2018 28 3 earth Jun 11, 2022 #6 Wow thanks for the help, currently have a basic E841CAB Here is the view, just trying to figure out what options I have to improve the view.
looney2ns IPCT Contributor Sep 25, 2016 16,757 24,987 Evansville, In. USA Jun 11, 2022 #7 Answer the questions, that will help.
P passat774 n3wb Jun 17, 2018 28 3 earth Jun 11, 2022 #8 I am thinking plates and people, not much action typically. I have been able to grab plates most of the time with my one basic camera,,
wittaj IPCT Contributor Apr 28, 2019 32,912 62,983 USA Jun 11, 2022 #9 Do you want plates at night? Are you able to capture plates at night now? You may be one of the rare instances in a cul-de-sac where you can at night, but I think most would recommend a dedicated camera for plate reading as @bigredfish shows. Reactions: sebastiantombs and bigredfish
bigredfish IPCT+ Member Sep 5, 2016 32,968 80,042 The Swamp Jun 11, 2022 #10 passat774 said: Wow thanks for the help, currently have a basic E841CAB Here is the view, just trying to figure out what options I have to improve the view.View attachment 130449 Click to expand... Raise it higher like 10-12 feet and add cameras.
samplenhold IPCT+ Member Aug 8, 2018 8,814 31,274 Spring, Texas Jun 11, 2022 #11 passat774 said: Here is the view, just trying to figure out what options I have to improve the view. Click to expand... You would have to define 'improve'. What needs improving? passat774 said: I am thinking plates and people, not much action typically. Click to expand... Plates and people? Plates are understandable and as other's have stated the cam and asked if night was important, I won't go there. That's a fairly wide view. Just where in that view do you want to get people. And I am taking it you mean face ID.
