- Jan 26, 2017
- 19
- 2
I have a somewhat unusual application in mind. I'd like to stream some pinball machine play over twitch/youtube. I'd need to connect three cameras to capture the playfield, scores on the backbox and the player. Typically people use cameras connected to transmitters and receivers to connect the video to a desktop computer that then goes into OBS and then to the internet.
I was wondering if it was possible to use IP cameras instead, just connecting via Cat6 POE. This would eliminate the need for batteries and transmitters/receivers, but would add the hassle of dealing with three Cat6 cables. The rig would need to be mobile, being able to roll to one pinball machine to another, so the cable management might be tough. My main question, though, is whether IP cameras would have the quality needed for this application. I know picture quality, latency and the ability to capture fast movement (in terms of the playfield camera at least) is important and not sure whether IP cameras have the right capability in this regard.
I'm attaching what a typical wireless rig looks like. Any advice is appreciated!
