Hello everyone. I have a Laview NVR which has POE for my cameras. The only way I've managed to get the cameras to stream to Blue Iris is by enabling virtual host (See image) in the NVR which assigns a port to each of my cameras to the NVR IP address. Example my NVR IP is 192.168.86.23 and I can access each camera in BI via IP/Port 192.168.86.23:65001, 192.168.86.23:65002, 192.168.86.23:65003, etc and I have it selected as Generic ONVIF/RTSPS/HTTP tunneled in Blue Iris (See image).
My question is the following since when I try to stream more than 1 camera on BI it kills my CPU to 100% (i5-2500k and I've done all the config changes mentioned here for optimizing) is should I invest in a POE switch to connect my cameras to so I can stream directly from each camera since it'll have it's own static IP to Blue Iris or would that not make a difference in performance?
