S SaltyDog n3wb May 10, 2021 6 0 Australia May 5, 2023 #1 Hi, Is there a way to stream a webcam to Blue Iris over wired lan with audio? I am currently using a raspberry pi with motioneyeos. It works great but motioneye does not support audio. Thanks
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama May 5, 2023 #2 SaltyDog said: Is there a way to stream a webcam to Blue Iris over wired lan with audio? Click to expand... By "webcam" are you referring to a USB device? If you mean an IP camera then the answer is "yes". Reactions: Flintstone61
S SaltyDog n3wb May 10, 2021 6 0 Australia May 7, 2023 #3 Hi, I mean USB webcam connected to rapberry pi
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama May 7, 2023 #4 SaltyDog said: Hi, I mean USB webcam connected to rapberry pi Click to expand... If you can get the pi to stream RTSP with audio then Blue Iris can likely show it with audio. Last edited: May 8, 2023
