A few days ago I noticed the image on Cam 1 was frozen on IVMS 4200. I logged into my 7608NI and found that I had a substream picture but not mainstream. The only way I can get mainstream back up is change Video Quality from Medium to Low (Anything above Low and I lose mainstream) or lower the resolution from 2048 X 1536 to 1080P. Bitrate is set to 4096. Increasing or decreasing bitrate has no impact. Logging into the camera itself I do get a mainstream picture regardless of settings.
Rebooting the NVR does not resolve the issue nor does resetting the camera to factory settings. I am using the NVR's POE ports.
Has anyone else had this problem?
Update: Problem appears to be with the camera. I flipped cables for channels 1 and 2 and the problem followed. Both channels 1 and 2 are DS‑2CD2032‑I running firmware 5.3.0
Thanks!
Thanks!
