G Gary Taylor n3wb Jun 14, 2019 4 0 Florida Jun 14, 2019 #1 Can I redirect recording data to any drive other than C:? I'd like to use a USB connected hard drive. Thanks
mikeynags Known around here Mar 14, 2017 1,041 944 CT Jun 14, 2019 #2 You can move them over to an external drive. Under options, look at the "Clips and archiving" tab. There you have several options on where to store clips.
SouthernYankee IPCT Contributor Feb 15, 2018 5,176 5,338 Houston Tx Jun 14, 2019 #3 You can easily store the clips on a portable drive. Drone the bi folder location, then assign the cameras to the folder. Most purchased portable drives will not last if using continuous recording from multiple cameras. You will kill the drive.
