Stopping camera from phoning home
tigerwillow1
5,177
11,873
USA, Oregon
There's been a lot of discussion on how to block cameras from accessing the Internet. What about this one: If you set up the camera with a static IP and set the default gateway to a non-existent IP address on its subnet, won't that block it from accessing the Internet?
yeah but tha'll also block your VPN from working with a TAP/Routed setup; your better off creating firewall rules on the router to enforce network policies.
Most good routers/firewalls will let you define a group of hosts, make a group with all the IP's of your cameras, then create a rule blocking all inbound and all outbound traffic for that group.
Many firmwares are now using built-in IP addresses for DNS resolution. If you leave the DNS server IP blank, they'll still attempt to phone home using their built-in DNS addresses. As nayr and alastairstevenson said, block the traffic at your router.
Sure - but if they can't figure a gateway, there is no way out of the subnet.
It all depends on how good you are at networking, and your setup. If you do a static reservation in DHCP, and are also able to give a non-working gateway, then that may work. Another option, which I'm planning is have a separate VLAN/network for the cameras, and make the NVR (or in my case BlueIris) multihomed, so I can see my cameras remotely only via the blueiris interface.
Ideally though, blocking at the firewall is easiest, and (usually) most straight forward.
