Thanks for letting me know about the DMSS app. I found this on the app store. I can use this app on my phone to view these cameras without having an NVR installed?
Using the app I can connect directly to these cameras for viewing?
So the DMSS software resembles using an nvr system?
Trying to make sure I understand all this correctly.
Also, is there any particular app suggested to use on my phone? Or would the DMSS app be best or something more like the BI app?
You also mentioned a browser based UI3 platform. Do I need to install anything on my phone for this to work? Or just launch the browser and enter an IP address to gain access to all installed cameras?
The major difference is with an NVR you can sort by the AI stuff. With just DMSS and an SD card in the camera, it will be event lines on a timeline. I did that when I had one camera that turned into two, turned into 3 and then without a NVR controlling everything, it was useless.
The BI app will only work if you have BI running on a computer.
Unless you do some weird stuff, you wouldn't run DMSS and BI. Most of us isolate the cameras from the internet via dual NIC in the BI computer, so DMSS can't access the cameras. You would have to put the cameras on the same IP subnet as everything else for DMSS to work.
Yep the UI3 is just open a browser on your phone and type in the IP address and probably need the port number like :80 or :81, whichever BI is.
