- Nov 24, 2015
- 19
- 6
I have a couple of cams around the house, all of which are on fixed IP addresses, set at the camera. I have recently opened a support case with the supplier of one of the cameras as it is dropping off the network. On reviewing the network settings the support staff have stated the following:
and then following on, when she had noted that I neglected to fill in the address of a DNS server on the camera config settings:
Now, I think I'm being spun a line. I want my cameras on fixed IP addresses so I can find them on my browser, I certainly don't want my cameras connecting to the internet, so why should I have the DNS server set?
Am I right in my reasoning? I understand from the point of view of support staff its easier to diagnose a problem from a known configuration, but I fail to see why having a fixed IP address would cause problems.
And yes, I've checked, there are no IP address conflicts..
Any thoughts anyone?
 We do not recommend setting the camera to a static IP unless this is something that is specifically required by your router/local network as doing so incorrectly can cause issues
The DNS servers are essential for the camera to be able to connect to the internet and to the app properly, without these you will see issues with the cameras connection
