Static IP setup , Camera, router, or both?
oldspyguy
Jan 8, 2026
59
32
Cold North
I want to reduce/eliminate issues with my cameras and other devices on my dedicated network especially after a power interuption.
Which would be the better option, on the camera, in the router, or both?
Basic layout of my network as of now.
There is one router going to a managed switch with 6 cameras on the switch and a 5.8g wireless bridge to building two.
Building two has unmanaged switch with 6 cameras and another 5.8g wireless bridge to building three.
Building three has unmanaged switch and 4 cameras.
I am guessing I should also set static IP's for the wireless bridges as well?
Thank you
I would apply static IP's to the following:
  • Managed switch
  • Wireless bridges
  • Cameras
I would put the bridges and switch together on their own IP range/scheme
You have not mentioned how you are recording the cam feeds (BI?, NVR?) Ideally put the cams on their own scheme/range as well.
</$0.02>
Static on the camera/device is better for ultimate reliability after power interruptions. Reservations on the router are convenient and low-risk, so do both if your router supports it. This combo eliminates almost all the common post-outage headaches with dedicated camera networks.
+1 to both the above, I'm a fan of static IP's......
I make the router's (LAN is 192.168.1.1) DHCP pool range from 192.168.1. 2 to 192.168.1.199 and that leaves me with 192.168.1.200 to 254 for me to assign to my cameras, wireless bridges, printers, etc.
I keep all those assignments in a simple spreadsheet and in Blue Iris the camera name has the IP in it such as "Side Doorbell 211" or Backyard N. 216". :cool:
I make the router's (LAN is 192.168.1.1) DHCP pool range from 192.168.1. 2 to 192.168.1.199 and that leaves me with....
OP, are you planning to remote in (using VPN) to check on your cameras? If so, be mindful of the following... On several occasions I have encounter a conflict when trying to accessing a clients BI system via VPN from another home network. Both the LAN I was currently on... and the clients LAN were a 192.168.1.x network, and I was not able to access the remote BI system via VPN.
I discovered it is due to the remote routers' VPN server configurability... or should I say, lack of. The VPN server service on many routers will provide (by default) the VPN client with a different IP range. If this is the case, you should have no troubles connecting. For the other routers that assign the VPN guest an IP similar to the routers LAN config (192.168.1.x), you'll have difficulties when you are also on a network with the same IP scheme (192.168.1.x).
My standard practice now is: I change the LAN IP scheme of my customer's router away from the default of 192.168.1.1. Regardless of their router's VPN server configurability, they should not encounter any issues when connecting from the home network of friends/family, etc
^ Good point.
I used 192.168.1.XXX as an example merely to point out that the DHCP pool range can be moved as needed to accommodate particular needs and certainly the router's LAN/ gateway can be changed as well.....and often that's the easiest solution that we see on IPCT when a member gets sent a router from the ISP with a completely different subnet as the orignal router and they struggle with changing every camera's IP instead. :cool:
My personal router is 192.168.200.XXX.
Just do the Camera's, My Ubiquiti point to point bridges always came back with same IP. it was 2-3 of the 18 Dahua style cams that would bollox the system after a power outage. I always thought I was saving them with Static, but apparently I missed a couple. Switch should be fine as is.
I am just starting to investigate BI and starting to understand how hardware intensive it is when AI is utilized. For this use case there will be no remote access needed, for now lol.
I have a master spreadsheet as well with all devices, pw's, mac, model, spec, etc. Has saved me a few times when my old memory fails me...
Yes, it is unique, found out the hard way lol
Thank you all for your advice, once I get my network set up properly the next step will be sorting out what to use for video storage. I have a generic dvr/nvr most cameras are IP with onboard storage as well.
Yes, I recommend assigning a static IP to everything involved. Don't forget to assign a static IP to the Blue Iris computer too!
Managed switches and wireless bridges don't strictly need their management interfaces to be assigned a static address, because they should be transparently passing along all network traffic regardless of their management interface configuration. But I do recommend assigning static addresses to those anyway, because it can be helpful for troubleshooting in the event that the DHCP server (router) is offline.
I manage so many networks now, I use multiple spreadsheets! One for each subnet, and another to list them all in one place with links to the individual sheets.
Also, years ago I stopped using common default IP ranges whenever possible (e.g. 192.168.0.x, 192.168.1.x) in favor of choosing IP ranges that other people are unlikely to have chosen. It helps when working with VPN connections especially.
Thank you
Set static IPs on all cameras and wireless bridges in the device's configuration page.
Thank you
In your case, I wouldn’t set static IPs directly on every camera. The cleaner way is to leave the cameras on DHCP and create reservations in your router. That way each device always gets the same IP, but you’re managing everything from one place. If you hard-code static IPs into 16 cameras and later change something (subnet, gateway, router, etc.), you’ll have to touch every single one. With DHCP reservations, it’s much easier. And yes, definitely give the wireless bridges fixed IPs too (again, through DHCP reservation). You don’t want those changing after a power outage.
Most of the time, the problems after a power interruption happen because devices boot before the router is fully ready. If outages are common where you are, putting the router and maybe the main switch on a small UPS can save you a lot of headaches.
Many older routers and especially modem/router combo units supplied by ISP's do not have the option to make IP reservations.
That is not so. You can just log into the new router and change the subnet of its LAN/gateway.....you don't "have to touch every single" camera.
Most of the time, the problems after a power interruption happen because devices boot before the router is fully ready...
That said... If cams & recorders are each set to their own static IP scheme, they will be operational before the router completes booting. Otherwise, all the DHCP set devices will need to wait for the DHCP server service in the (slower booting) router to come online.
Additionally, if your are using a DHCP reservation model, this requires each cam to be connected to/thru router. This is not the best practice for building out a camera network due to the higher network traffic inherently generated by the cams. Sure, some routers out there can process the traffic. Most here are using residential class hardware, which will not be as effective as the more expensive hardware.
My experience has been that setting static IP on the device is less overhead. If you create DHCP reservations on the router, odds are when the router fails, you will not be able to simply export/import the reservations to the replacement router. This requires entering the all the IP's & MAC addresses again.
I’ve simply set static IPs on the cameras in a range above the range I set for DHCP on the router. Haven’t had a problem in almost 10 years
Reactions: looney2ns
Same here, as in my post #4......has never failed. :cool:
Yes to all the comments here thus far
and if you are wondering what DNS to use, opt for Cloud Flare
Primary 1.1.1.1
Secondary 1.0.0.1
Handle this at the router with DHCP reservations rather than setting static IPs manually on every camera. That way each camera, switch or wireless bridge always gets the same address, but the addresses are still managed in one place. Give the wireless bridges reserved ip addresses too, especially since you have multiple buildings and quite a few cameras. Just make sure the reserved addresses are outside the normal DHCP pool, or otherwise configured so you don’t create an address conflict. This also makes replacing a device or changing network settings much easier later.
That doesn't make sense.....how would a decent router create an address conflict by assigning an IP to a device from it's own DHCP pool if it accounts for its own reservation list?
Reactions: alastairstevenson
