OK, looks like there have been a few threads semi-associated with this, but I would like to confirm compatibility before I make a change to my ISP.
First of all, I am currently using Starlink and have several static IP cams connected via wireless and unmanaged switches as needed. Everything is working fine, but I am looking at a potential cost savings by switching to Comcast/Xfinity cable which has recently been installed in the neighborhood.
1st question is, does Xfinity play well with IP cameras set with static IP addressing, especially when using a modem supplied by Comcast?
(They are running a special where their modem is supplied free for 1 to 2 years depending on the package selected, but I am not ruling out purchasing my own equipment/model if needed.)
2nd question is, what type of LAN IP addressing does an Xfinity modem use, 192.168.0.XXX or 192.168.1.XXX?
Reason I ask is, I went from 192.168.0.XXX or 192.168.1.XXX addressing when I upgraded to Starlink, and it was a pain readdressing each camera since they are currently independent of an NVR. Although I have an NVR on standby, I am hoping I may be able to retain the current setup and addressing and maybe name any new modem the same as the current name and password.
I like to set static addresses so I easily know where to access each camera.
Any information associated with this would be appreciated!
Thanks!
Thanks!
