Hello again everyone.. I'm starting my 3rd system build and am trying to understand more of the technical stuff to keep improving on my system designs.
I have 11, QTN8037BC cameras. When I log into the camera itself under the video tab it shows main stream
2048x1536 3MP4:3
15FPS
bitrate CBR
Bitrate Kbps 4096
iframe interval 15
video H264.
I have 1 Dahua PTZ 4x zoom 2mp
1920x1080 @24.7 FPS
FPS 25
CBR
Bit Rate 4096
Iframe 25
Total 12 cams
Is there an easy formula to figure storage and how much a system can handle. I have been looking at the chart of systems and how the compare but is there a formula to figure this as well. Also if anyone has any other technical data they use to plan out systems I'd be interested in that as well.
System
i7 6700
16 GB ram
120ssd
8tb WD Purple HD
Price $390 June 2018 ebay I also added the ssd and 8tb purple drive to this after the fact
This is the last system build I did and its working great.
CPU is at a steady 36% using all the tweaks to optimize BI that I found in the Wiki pages
Ram is at 5.51G
The new system Im thinking that I want to give him all ptz's like the Dahua up top. I like that they can home themselves after a certain time so it gives the client the flexibility to be able to look around with each camera for closer inspections and not have to worry about putting them back to the static home position. The new system is also going to have more cameras maybe up to 20 and I would like to jump them up from 2mp to maybe 4 mp on at least some of them. They are going in a bar so they have to work well in darker situations. I like the Dahua that I currently have in another bar because I have it staying color and the picture looks great. I've been reading some of the current posts and I'm trying to get the best current system for a reasonable price like the one above and also I'm looking for links to some Dahua PTZ's that might be current that people are happy with in the 2 to 4 mp range with a 4x zoom. The one I had up top was about $150 on amazon which is where I'll probably look for the new cams but thought I'd see what you guys had to say first. Maybe a couple static dahua's as well if there are some good recommendations.
Really looking forward to this build as I'm laying everything out and planning the build versus bit by bit. I just love this software. Thanks again for the help I can supply more info if needed. And I'm taking notes.
I saw this system on ebay but it has a T after the 7700 and I thought that means that its not as good. Is this correct thinking?
HP Slimline Desktop Intel Core i7-7700T 12GB 1TB Hard Drive
Bid is $250
Links to the cameras Im thinking about. Any thoughts on these?
https://www.amazon.com/dp/B07R3VNN9T/?
coliid=I32Y46F1OLDEKC&colid=1U2T2IKAT95H3&psc=0&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B074J8NJY...olid=1U2T2IKAT95H3&psc=0&ref_=lv_ov_lig_dp_it
2048x1536 3MP4:3
15FPS
bitrate CBR
Bitrate Kbps 4096
iframe interval 15
video H264.
1920x1080 @24.7 FPS
FPS 25
CBR
Bit Rate 4096
Iframe 25
Total 12 cams
System
i7 6700
16 GB ram
120ssd
8tb WD Purple HD
Ram is at 5.51G
Bid is $250
