They are plugged in one at a time as I am trying to reset. Yes, I know that the same IP addresses are a problem.
i am recording to a Synology NAS but that isn't the problem.
You have nothing to lose by trying what @c hris527 did here and what @Parley did here.I don't see a green light but I am able to depress the button and hear the reset clicks without removing the board.
I found this thread from 2018. Do you guys think these cameras, purchased in 2017, require an email activation code in the software but no longer exists in the config tool?
https:/ipcamtalk.com/threads/cannot-change-ip-address-on-dahua-ipc-hfw8232ep-z.25565/
Yes. I've never seen an issue with Dahua cams like you are having unfortunately.Thanks Chris for the info. I just tried everything you suggested. No luck. I don't have IE so I had to use the Edge IE Legacy.
It's a shame. I was stupid not to think the initialization had a shelf life.
Are new Dahua cams easy to initialize and reset (if necessary)?
The only thing I can think of offhand is that with the newer cameras you don't need to open them up to get to the reset button. For a less helpful comment, I've been following this thread with some disbelief of what's happened to you. Over about 6 years I've brought up about 30 cameras without much fanfare, using config tool. This includes a couple of HDW4231EMP-ASE. I just plug them into my network (not on 192.168.1.xxx), one at a time. Config tool finds them, initialize works, I change the camera to a predetermined IP address, and then use a web browser for the rest of the camera setup. If it was possible to just hand one of these cameras to me, I'd love to try to get it going. I can see getting a defective camera, but 4 of them in one batch? Pretty long odds for that.Are new Dahua cams easy to initialize and reset (if necessary)?
Same here.Yes. I've never seen an issue with Dahua cams like you are having unfortunately.
That's a good Tip..works wellExplorer is still baked into Windows.
Open up Notepad and Copy this text below in the blank space and do a save as IE.vbs and make it a shortcut on your desktop and then plain ole Internet Explorer will run again.
CreateObject("InternetExplorer.Application").Visible=true
You are 100% correct, Something seems really off here, I was actually going to ask him also to ship me one.The only thing I can think of offhand is that with the newer cameras you don't need to open them up to get to the reset button. For a less helpful comment, I've been following this thread with some disbelief of what's happened to you. Over about 6 years I've brought up about 30 cameras without much fanfare, using config tool. This includes a couple of HDW4231EMP-ASE. I just plug them into my network (not on 192.168.1.xxx), one at a time. Config tool finds them, initialize works, I change the camera to a predetermined IP address, and then use a web browser for the rest of the camera setup. If it was possible to just hand one of these cameras to me, I'd love to try to get it going. I can see getting a defective camera, but 4 of them in one batch? Pretty long odds for that.
So you must have had it on your network with the router connected if I'm understanding correct? Sounds like buggy firmware but glad you got it.Ha! I DID IT!
After spending countless hours trying to create a static IP and trying everything I could think of and everybody's suggestions, I tried something different. By accident.
I reset the camera. Once again the strange IP was shown. This time I clicked DCHP. I saw a green check mark and a password window appeared when I clicked "edit".
I set the password and then was able to log in, see the camera and change the IP to static.
I have no idea how, or why, it worked. I would think it was a conflict with the router except I took the router out of the equation as suggested above, and it still didn't work.
Thanks for all of your suggestions and for following along.
It was the last time I was going to try it. Next I was going to take one of you up on your offer and ship it out. At least I would know what I was doing wrong.
Yes, it was on the network when the DCHP assignment worked.So you must have had it on your network with the router connected if I'm understanding correct? Sounds like buggy firmware but glad you got it.
