SSD or HDD for BI/AI jpegs Default Input Path?
Pentagano
Getting comfortable
Dec 11, 2020
665
300
Uruguay
I'm using deepstack with the AI tool
Which drive is best to use for the BI Jpeg trigger folder and for AI Default Input Path?
Would I observe slower performance using an HDD spinner for this Path? Would using my SSD perform too many writes and reduce its life prematurely?
Thanks
Use the platter drive. No need to use the SSD since speed is not that important for this and you won't see any difference anyway. Remember the life span of an SSD is dependent on writes so no need to write to it unnecessarily.
Reactions: TonyR and Pentagano
