Hi
I was wondering whether anyone has had any experience with the AP009 as I am having a problem finding the camera on the network even though everything is setup correctly and i can view the camera on wireless from my mobile internally on wifi and also on 3g.
I have tried running the p2p finder and also the viewer application and neither can see the device on the network, i am using the same subnet as my PC's and they are all connected through the same AP so there should be no connectivity problems as the IP is set dynamically.
Has anyone got any further ideas as i will be looking into setting this up as a camera system managed by either ZoneMinder or Motion on a Ubuntu box but can't get past the first stage of even connecting to the camera from my windows laptop with the manufacturer software.
Thanks
Brad
Thanks
Brad
