SPSS Lite, how to record cameras connected to it without NVR?
wozzzzza
Pulling my weight
Jan 5, 2015
483
110
dont have an NVR but have dahua IP cameras, i have SPSS Lite set up and installed, i can see the cameras on it, how do i set them to record 24/7??
Found in the SmartPSSLite User's Manual:
  • Set up the Local Path for recorded videos in Chapter 4.4
  • Refer to Table 8-3 "Description of live view operation parameters" to record videos in the current screen window.
Reactions: RyanB
Found here:
To set up continuous recording in SmartPSS Lite, configure the recording mode to "Manual" and set the Max Record Time to a desired value (e.g., 900 for 15-minute clips). Alternatively, you can use the "Constant" record mode, which is designed for continuous recording.
Here's a more detailed breakdown:
1. Accessing Recording Settings:
  • Right-click on the video feed: In SmartPSS Lite, right-click on the live video feed of the camera you want to configure.
  • Select "Edit": A menu will appear, choose "Edit".
  • Navigate to Recording: Click on "General" at the top right, then select "Recording" from the dropdown menu.
2. Configuring Recording Mode:
  • Manual Mode: Set the "Mode" to "Manual".
  • Max Record Time: Set the "Max Record Time" to your desired recording clip length (e.g., 900 for 15-minute clips).
  • Constant Mode: You can also choose "Constant" for continuous recording if available.
3. Starting Recording:
  • Start Recording: Once you've configured the settings, right-click the video feed again and select "Start Recording" to initiate the recording.
Reactions: RyanB
have you tried any of this or just copying and pasting?? i cant find any of these settings anywhere
