reflection
Getting comfortable
Quick follow-up on the 4-port poe extender that I linked. More testing with it and I turned on the IR LEDs and my power draw for the three cameras went over the 15.4W limit for 802.3af. All three cameras shut off and would not come back online.
I thought it would not be an issue because my switch supports 25W+ (802.3at) and the 4-port poe extender indicated that it supports a 802.3at input.
Upon debugging my switch, I noticed that the extender does not negotiate for more power. Therefore the switch was only granting the extender 15.4W by default. When the extender tried to draw more power, the switch was smart enough to shut off the power to the port. The fix was to tell the switch to allow the port that connects to the extender to have more power. After that, things worked fine.
In summary, the 4-port poe extender does not negotiate power based on standards for PoE. Therefore you have to turn off PoE negotiation on your switch port if you need more than 15.4W.
