- Sep 10, 2017
- 83
- 18
Im about to run cat6 from the house to the shop and before going through the underground pipe I notice this big communications wire. Its from the telephone connection we had and gave up a few years back. The cable is dormant but looks stout with a bunch of wires. Would it be good practice to splice the cat6 to this then splice again at the shop in the junction box where this comes up? I am connecting the ethernet cable from a PoE switch in the hous to a PoE switch on the shop to mount IP cameras on both. This will run from the PoE switch to another PoE switch. This line will have 3 splices on it if I do it. Will this work? I know the wires are a larger gauge than cat6 and appear/feel like solid copper. Although dirty, its about 8-9 years old at the most.
Since theres not a string in this pipe Iwas going to pull the black one to run string and wire if needed, if not I'd like to use it.
Thanks
Thanks
