If you are using turret cameras, sometimes the spiders like to hide in the gap between round camera enclosure and the mounting case. The FL Mud dabber Wasps love to crawl in there and make their nests. I use the foam weather stripping material between the enclosure and camera to keep them out. No need to remove the back strip to expose adhesive material because it is just a press fit with the foam.
