I've started this new thread for technical details on my Speeder detection setup. I call the package "OPENRoad". As time permits I will update this post.
Please use other thread for any political talk, objections, comments, or advice. Administrators please delete or move posts not related to technical issues at hand.
Political thread -> https://ipcamtalk.com/threads/my-speeding-dectector-setup.42045/
Speeder control - Move video from temp location to permanent spot. Backups correct LPR camera and does a LPR plate scan of speeder.
Adjust LPR Cameras
Pictured here are the outside components.
A speed sign using a Speedster III sports radar setup. I suggest starting with this $300 radar to first sample speeds of oncoming vehicles. If they aren't going over 35 mph, give up now.
There is a picture of the speed sign control box. It contains 4 network ports, 4 12v power jacks, and 2 control jacks, one for the sign, and one for warning lights.
The green board is a network switch to distribute the network. We use a Brainbox to control the relay to turn the speed sign off at 35 mph. The Brainbox is connected to the master computer via the network.
The silver device is a voltage converter changing 12v to 15v for the speed display sign.
The pictures of the back post with the two boxes are the radar setup.
The top box is the Speedster III radar gun sealed into a water tight box. It communicates to the speed display via RF signals. We hope to replace the display at some point.
The bottom box is the radar control that collects the data to be transfer to the master computer.
It contains a DRU III radar module, a serial to network converter, and a network switch. We are reworking this box. Pictures will be coming soon.
Each post has two cameras, one for LPR, an one for wide view. We decided on using 4 - Loryta IPC-HFW5241E-Z12E IP Cameras.
The middle post was suppose to use for signage, and extra cameras but turn out it is useful as a IR light blocker. The 4 cameras are point at each other so it is important not to flood them with each others IR lights.
more to come....
Adjust LPR Cameras
more to come....
