- Feb 15, 2017
- 1,505
- 1,160
That tree caused it to stop.. landscaping needs adjustedDid it get stuck on the tree at the end or was that the edge of some range it was configured to track within?
I have an old ptz that will display the horizontal and vertical degrees of camera.. is that what you mean? Sure dahua can do thatIt would be kind of nice if PTZs encoded information (precise very detailed information) about their movements into their video. There are some fun things you could do with that.
I now you can do an overlay, but that's not what i mean. I mean embedded metadata (not visible) with things like position, rate of movement, etc to the full level of precision the camera uses internally.I have an old ptz that will display the horizontal and vertical degrees of camera.. is that what you mean? Sure dahua can do that
Oh ok I see what you mean.. if you have a wide open view with the dahua 59225 its unreal how accurate and consistent the tracking isI now you can do an overlay, but that's not what i mean. I mean embedded metadata (not visible) with things like position, rate of movement, etc to the full level of precision the camera uses internally.
