Speco Technologies N16NXP 16-Channel 4K UHD NVR (No HDD) $100 deal .. older discontinued model.
mat200
17,444
29,412
FYI -
Spotted this deal when replying to a thread, wanted to share it separately.
Older retired NVR model 16 PoE ports + room for 4 HDDs if I got the specs right.
BH #SPN16NXP • MFR #N16NXP
In Stock
Share
Print
$99.95
FWIW - it may not have some of the more advanced features that many of us like .. still should be a decent options for those on a tight budget and needing the basics or who may want an extra box ( perhaps a good, Look thieves.. take this box, not the Blue Iris box that is hidden away .. ;)
We used to have a speco mobile DVR at work. Hated that thing. Was clumsy to use and their support was lacking as they only supported distributors, not consumers.
Reactions: user8963
iirc some of the past Speco NVRs were Dahua OEM .. so run the Dahua OEM firmware ..
Learned something new! They’ve already been replaced so not my problem anymore :)
fyi - not certain of the Speco older models, or DVRs .. so I can't be certain the NVR / DVR you looked at was also a Dahua OEM one ..
Found a couple of manuals online which appear to address this NVR .. looking for a confirmation of the OEM on this NVR ..
Oh it's back. I bought one last year April2020 and flashed it with the NVR4XXXX 4kS2 V3.216 when the N8NXP was being discussed. IIrc it identified itself as the 4416-16p-4ks2. Havenot tried the v4 firmware on it
Thanks to @33696933 for the info .. here's what I found on it..
( note related discussion on the 8port version was here.. Help identifying Dahua OEM NVR from Speco N8NXP )
NVR4416/4432-16P-4KS2
16/32 Channel 1.5U 16PoE 4K & H.265 Lite Network Video Recorder
16/32-channel IP video access
Smart H.265+/Smart H.264+/H.265/H.264; H.265 auto switch
Max 200 Mbps incoming bandwidth · Up to 8MP resolution for preview and playback
8-channel decoding@1080p (30 fps)
AI by Camera: Perimeter protection; SMD Plus; people counting; heat map
Support IPC UPnP, 16 PoE ports
ref:
Reactions: Arjun and looney2ns
Seems like a great deal for someone just entering this market, would have been extra slick if it could support the new SMD firmware Andy posted earlier :D
