- Feb 12, 2017
- 2
- 1
Hello,
I'm trying to figure out if this Speco N8NSL NVR is a Hikvision or Dahua rebrand, and if there is a way to flash a newer firmware on it than the manufacturer provides. Here's a link with photos: link. I presume Speco stopped supporting this device because they want to sell more NVRs. I contacted them and they provided the attached firmware file which they say works for the N4NSL and N8NSL. I've done about as much as I can with binwalk and trying to mount CramFS files with no luck:
I then try to mount it with fusecram (filename) (mountpoint) which doesn't give any errors, but when I try to navigate or stat that path, I get:
My goals were to try to recover the login/password for the telnet "root login: _" prompt, and to determine which hik/dahua hardware this is to download more updated firmware.
Does anyone have any thoughts on this?
Code:
root@parhelia:/home/pd# binwalk -e main_n4nsl_speco_5.2.2p_20180120\ \(1\).bin
DECIMAL HEXADECIMAL DESCRIPTION
297144 0x488B8 CRC32 polynomial table, little endian
329675 0x507CB Copyright string: "Copyright (C) 1998, Thomas G. Lane"
348192 0x55020 uImage header, header size: 64 bytes, header CRC: 0x4AA8F10C, created: 2014-09-18 12:50:01, image size: 2078672 bytes, Data Address: 0x80008000, Entry Point: 0x80008000, data CRC: 0xE2CD8ABB, OS: Linux, CPU: ARM, image type: OS Kernel Image, compression type: none, image name: "Linux-3.0.8"
370360 0x5A6B8 gzip compressed data, maximum compression, from Unix, NULL date (1970-01-01 00:00:00)
2428976 0x251030 uImage header, header size: 64 bytes, header CRC: 0xB9A477, created: 2018-01-20 04:15:02, image size: 21491712 bytes, Data Address: 0xE1100000, Entry Point: 0xE1100000, data CRC: 0xCE6D051C, OS: Linux, CPU: ARM, image type: RAMDisk Image, compression type: none, image name: "initrd in cramfs"
2429040 0x251070 CramFS filesystem, little endian, size: 21491712 version 2 sorted_dirs CRC 0x1B4D7559, edition 0, 5724 blocks, 371 files
Code:
bash: cd: mnt1: Transport endpoint is not connected
