Hi there,
This is my first post and the reason for my visiting this forum. Hoping the level of expertise on here will give me some options to explore to resolve my camera issues.
So...
I have an Argus 2 from Reolink. It works very well, good images, easy to install/use, wireless, solar/battery-powered, happy with the software and app that comes with it, and so on.
However... my requirement is that guests can view the stream just by opening a link in their browser on their device. The Argus 2 doesn't do this - I've discussed it with Reolink and it's not happening. That unfortunately means my guests will need the admin username and password to view the stream, which obviously gives them full access to the camera, its settings and any recordings. There's no user account setup either, so I can't do a workaround that way.
Anyone have any suggestions on suitable cameras? Ideally under £120, but I'll consider others if the benefits are there.
Cheers!
So...
Cheers!
