My notes are updated as I learn new things. It is sort of a quick start, get your head around it.
Also I get tired of see the same questions, so I tried to answer them before they are asked
My standard welcome to the forum message.
Please read the
cliff notes and other items in the
wiki. The wiki is in the blue bar at the top of the page.
Read
How to Secure Your Network (Don't Get Hacked!) | IP Cam Talk in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2) Use Dahua starlight cameras or Hikvision darkfighter cameras or ICPT Night eye cameras (
https://store.ipcamtalk.com/) if you need good low light cameras.
3) use a VPN to access home network (openVPN)
4) Do not use wifi cameras.
5) Do not use cloud storage
6) Do Not use uPNP, P2P, QR, do not open ports,
7) More megapixel is not necessarily better.
8) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
9) Do not use reolink, ring, nest cameras (they are junk)
10) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
11) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
12) use a test mount to verify the camera mount location.
My test rig: rev.2
13) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
14) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
15) camera placement use the calculator...
IPVM Camera Calculator V3
Cameras to look at
IPC-HDW2231R-ZS
Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW5231-ZE
Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE
IPC-HFW4239T-ASE
IPC-T5442TM-AS Review IPC-T5442TM-AS-LED (Full Color, Starlight+)
IPCT-HDW5431RE-I
Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
IPC-T5442TM-AS
Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A
https://ipcamtalk.com/threads/review-dahua-ipc-k35a-3mp-cube-camera.37581/#post-373517
Read,study,plan before spending money ..... plan plan plan
Test do not guess
