V vegaslineman n3wb Feb 10, 2017 16 4 Mar 9, 2017 #1 Anyone else having sound alert issues? I get the alert message on my phone. And testing sound alert works but the sound stops working.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,549 51,163 Alabama Mar 9, 2017 #2 Haven't had any issues. You've configured the following points to your liking?
V vegaslineman n3wb Feb 10, 2017 16 4 Mar 9, 2017 #3 Think the issue is the speaker outlet on front of box.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,549 51,163 Alabama Mar 10, 2017 #4 OK, so audio more dependable, OK, etc. when speaker plugged into rear light green jack instead of front panel headphone jack?
V vegaslineman n3wb Feb 10, 2017 16 4 Mar 10, 2017 #5 Ended up doing the same thing worked for a bit then stopped. Just wanted to eliminate BI, and since no one else having issues its probably an audio software issue.
